A problem with automation when creating a rule for github and adding a repository
Sofiia
October 19, 2025
I'm having a problem with automation when trying to add a repository while creating a rule for GitHub, although I added an integration with a github earlier:image.png
Thomas
October 19, 2025
This issue can happen if the automation rule doesn’t have the right permissions or if the repository isn’t properly connected to your GitHub account. Try checking that the app or integration has access to the repo and refresh the connection. Also, make sure your rule conditions and triggers are correctly set. Re-adding the repository usually helps fix it.
Gor Greyan
October 19, 2025
Hi @Sofiia
It means Automation does not yet have authorization from your GitHub organization to access its repositories.
  • Go to GitHub → Organization Settings → Third-party access.
  • Authorize the Atlassian Automation app
  • During the authorization, select the relevant organization and repositories that Lassian Automation should access.
  • Once done, return to Jira → Project settings → Automation → Connections → GitHub and refresh.
Also check the official documentation:
https://support.atlassian.com/cloud-automation/docs/use-atlassian-automation-with-github/?utm_source=chatgpt.com
https://support.atlassian.com/jira-cloud-administration/docs/integrate-with-github/?utm_source=chatgpt.com
Product Admin Site Admin
