I am trying to set up an automation rule (global) that accomplishes the following:
And then a secondary automation:
For the first automation, here is what I tried to set up:
Audit log is showing these two errors:
This rule was set up with the scope set to both of the projects.
Both projects are company-managed; Both projects are using the same scheme and workflow as well.
Can you please verify the existence of the fields for the creation in target Project B? There might be a config change.
Please attach a screenshot from the automation if possible.
Best
Hey @Tansu Akdeniz , screenshot attached below, with the create issue option open. Both projects should have identical fields and issue types, since they share the same scheme and workflow. Additionally, both projects have the same component and release versions listed, too.
You said projects are identical but I want to be sure.
Please check;
If everything seems fine, can you please only send summary and description as a parameter and remove other fields (if not required in MNG) in automation ?
Hey @Eric Van Pyrz
This worked for me:
In addition to what @Tansu Akdeniz suggested, something to look out for as well is are both projects classic or next-gen projects?
Hope you work it out!
