Automation - How to copy field data from linked issue when issue is linked into Description.
Harish Tuccapuram February 23, 2024
I'm trying to copy the linked issues to a story to the Description field of a story ticket via Automation. In the current issue, when a comment is added.
After reading up on this link.
tried to use this  "set": "{{issue.issuelinks.inwardIssue.key}}" however, it is not copying the linked issues key and summary to the description field any help would be appreciated.
Thanks!
Bill Sheboy
February 23, 2024
Hi @Harish Tuccapuram
For a question like this, please post an image of your complete automation rule, images of any relevant actions / conditions / branches, an image of the audit log details showing the rule execution, and explain what is not working as expected.  Those will provide context for the community to offer ideas.  Thanks!
@Bill Sheboy  this is what i was trying.Screenshot 2024-02-23 at 3.49.31 PM.png
Bill Sheboy
February 23, 2024
Thanks for the rule image...As some follow-up questions:
What problem are you trying to solve by replacing the value of the Description field with the linked issues' key and summary values?  That is, why do this?  Knowing that may help the community to offer better suggestions.
What is not working as you expected when the rule runs?
Are you trying to replace the value of the Description field or to add to it?
Regardless, the advanced edit with JSON is not needed.  Instead you may enter that smart value expression directly in the field.  Perhaps like this to add the values after the existing description.
atlassian, mindful member, mindful member badge, atlassian community, community kudos, community giveaway, atlassian swag, community values, empathy and kindness, badge challenge, atlassian learning, community engagement, swag giveaway
Earn a Badge, Win a Prize 🎁
Earning the Mindful Member badge proves you know how to lead with kindness, plus it enters you into a giveaway for exclusive Atlassian swag. Take the quiz, grab the badge, and comment on our announcement article to spread the good vibes!
Start here
