Good day!
Intro:
I have to create some automations for my project using plugin Project automation
Description:
Project issue type screen scheme has 2 types (task and sub-task).
Target:
Designed automation should change its dueDate depends on its sub-tasks's the latest dueDate.
Screen:
Thank you for your help!
I would suggest the following :
But after that I should to edit parent issue by JSON? There's no any parent's options.
Your solution is greatful! it's work.
I've decided to change start values from parent + subtask to linked issues (task has "blocks" and bug has "is blocked by").
How can I compare task's dueDate and bug's dueDate? And change task's dueDate to the latest bug's dueDate?
For example:
tasks' due - 20/Nov/19
linked bug's due - 30/Nov/19
Task's due must change to 30/Nov/19.
Screenshot:
Find this function:
{{now.isAfter(issue.created)}}
Is it possible to use smth like that?
{{issue.duedate.isAfter(triggerIssue.duedate)}}
