Automation for Jira - using OR in Advanced compare condition
Sandra Priedīte
I need to compare version name with 2 values, so that rule is executed if version name contains either value 1 or value 2.
Is it possible or I must create second "else if" condition which would contain exactly the same action?
Kirkie
August 31, 2020
It depends on what type of field it is.
I would suggest checking doing this with the Isuse Fields condition first. Depending on the field, it may let you check if the field is ONE of TWO different values you provide, which would give you what you need.
If that is not possible, then yes, proceed with an else if condition.
SERVER
