Automation rule : Error while creating same issue from JSM project to JS project
MamadouPathe_DIALLO July 26, 2021
Hello Everyone,
Getting this error while using Automation to create a same issue from JSM to JS project
Anyone can assist please?
Jack Brickey
My first guess would be that the issue type that triggered this rule does not exist in the one 2 one project. Is that possible? As a test can you change your rule to create a specific issue type in the one 2 one project that you know exists for example task?
Worked like a charm
Thanks @Jack Brickey
