Here's my rule:
--Trigger - Issue #1 Created
--Edit fields on issue #1
--Create Issue #2 with a link to Issue #1 (trigger issue)
--Add Issue #2's ID to a Parameter <---- HOW DO I DO THIS???
--Add a comment to Issue #1 Saying "This ticket has been linked to {{createdTicket.id}} - Click here to open {{createdticket.URL}}".
How do it grab the context from the created ticket (Issue #2) in the automation's scope so I can use the data?
Thanks for any assistance.
Jamie
There is a smart value to refer to the most recently created issue or multiple if you create several: {{createdIssue}} and {{createdIssues}}
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--createdIssue--
And so you can use {{createdIssue.key}} for your scenario.
Also please note: when using the Issue Created trigger, that can fire faster than the data is available to the rule. So it is a good idea to add a Re-fetch Issue action after the trigger, and before any next steps. That will slow down the rule and reload the data before proceeding. So, something like this:
