Automation to start comment but not to post it
Michail Kotantakis
Hello team
I amtrying to setup an automation that upon a selection from a drop down cutom field, it would start a new comment with a predefined text, but not post the comment, just start the comment with the predefined text pasted there, so the user can evaluate if any adjustment is required before posting it.
Any suggstions or help on this?
Regards
Mikael Sandberg
You cannot do this with automation, it cannot pre-populate the comment without posting it. You would need an app like Behaviours, Dynamic Forms, or Power Scripts in order to do it.
Michail Kotantakis
Hi @Mikael Sandberg
thank you very much for your input
i see that i need other tools for such kind of "automation/scripting"
Is there an example that i could have a look with similar behaviour maybe?
Regards
Mikael Sandberg
I know Adaptavist has a script library that you could check out, https://library.adaptavist.com/?_ga=2.16033461.2020747712.1679415481-2123515169.1679415481
Michail Kotantakis
@Mikael Sandberg
Thank you very much fro this
I appreciate, i will have a look and see how can i use some things to apply to mine or come with new ideas.
Best Regards
Like Mikael Sandberg likes this
