Has anyone found a way, as part of an Automation rule scoped to a single project, to check for the existence of a linked issue in another project?
One of my project admins has a rule which, when a specific component is set on an issue, clones the issue into a new project, and good design would have us check to make sure the cloned issue doesn't exist already.
I swear in the past I've never had an issue doing this, but now I see all of the components explicitly stating the scope. I work really hard to keep global rules to a minimum because maintaining 1,600+ people's business logic with 1.5 admins is not feasible, so I really do not want to make this a global rule.
It makes sense to me that single-project rules wouldn't be able to make changes to issues in other projects, but restricting searching seems like a pretty common use-case even within a single project.
There are two-possible solutions for searching for issues in different projects from rules:
That second one is not limited by the restriction of project-scope rules. However with the changes to the packaging model / limits for automation rules, using Send Web Request will count as a rule execution for the limits.
Thanks for this idea @Bill Sheboy...I haven't played with the "web request" action a ton, but it sounds like I have a reason to now!
That's not a new parameter as far as I know - when using a single Project rule, it's limited to the scope of the rule.
To achieve what you're looking for, you'd need to use a multi-project/global rule.
Ste
I have some documentation that I originally wrote back in 2021 that makes me think this wasn't always the case on Cloud...the screenshot is cut off so I can't say for certain, but the logic wouldn't work as it's written today unless the rule was set as global and I am 99% sure it wasn't.
I also know this was a "bug" that was only recently fixed on Server\DC.
I'm sort of assuming you are right Stephen Wright _Elabor8_ though that the scope is impermeable. Just hoping someone sees something genius!
Just for extra evidence, I found a post from 2020 from an Atlassian team member which confirms it is project-specific - see: https://community.atlassian.com/t5/Jira-Software-questions/Getting-a-JQL-from-another-project-in-automation/qaq-p/1459658#M95623
Ste
Wild! Have to look through this rule to see if I can figure out it's deal then. And maybe get my brain checked.
Maybe you could use a smartvalue comparison to see whether {{issuelinks.outwardIssue.project}} is equal to {{issue.project}}?
