I have a problem when using the Issue Collector.
Whenever an issue is created from the collector, predefined default values for some fields are missing. This doesn't happen when the issue is created normally.
Is there some sort of "reset", meaning that you have to define every field from the script when using the collector ?
@Gezim Shehu [Communardo] did you find a solution to this problem?
