HI Team,
I have installed Jira Application in AWS instance its running sucessfully in my Instance
But its not running on Browser can you please help me how to make it sucess
here are the instructions that I have follwed for installation.
I have installed by using tar file.
Kumar
Hi @Kumar,
Check the security group of the instance and make sure it allows traffic to port 8080.
Hi @Edwin Kyalangalilwa thanks for reply
here are the screen short of instance
the ports all are open
Thansk,
Kumar
Ok, check the Jira log files and confirm that the application started up with no issues.
What are you seeing in the browser when accessing from <instance-ip>:8080?
Hi @Edwin Kyalangalilwa I have entered my ip : 8080
this is message its showing
The thing is previously i have installed jira but i have done something and its also gone so I have deleted all the jira files that installed
and I have installed newly
In the Home Directory there is no "dbconfig" file is not there
Kumar
