Automation for Jira offers a Comment on issue action. You can choose the visibility of the new comment in the configuration of the action. I want to restrict it to a specific project role, say “Developers”. My user account is a member of this role, therefore this does work if I am the rule actor.
Alas, I want the author of the comment to be the special user “Automation for Jira”. (One reason for that being, that I’m added as a watcher to issues my account automatically commented on; another is that colleagues don’t realise I didn’t add the comment manually.) If I set the the rule actor to be Automation for Jira (which is actually the default), however, the execution fails because Automation for Jira is not a member of that project role:
“You are currently not a member of the project role: Developers. (commentLevel)”
I thought there might be two possible solutions:
This Knowledge Base article (for Jira Service Management) suggests that I could achieve my first solution either by adding the special user by its email address com.codebarrel.addons.automation@connect.atlassian.com or by manually adding it through a mass edit screen I have never seen before at https://{company}.atlassian.net/secure/admin/roles/ViewUserProjectRoles.jspa?accountId=557058%3Af58131cb-b67d-43c7-b30d-6b58d40bd077. The latter option actually worked for me, but that’s hardly maintainable because I (or a colleague of mine) would have to remember to do this whenever we add a new project.
Is there any other, better solution I haven’t considered yet?
