How to access remote issue links by smart values?
Louis_Zhang
February 19, 2020
I'm writing a rule to send Slack notifications with the 'Automation for Jira' add-on.
Unlike other issue fields, I can't get the remote links by smart values like '{{issue.key}}'.
Any walkaround to fix it without using a groovy script?  Thanks
6 votes
Daniel Eads
March 5, 2020
Hi Louis,
You can use the issuelinks information in Automation, although as you discovered it's not as straightforward as just calling other fields. The issuelinks object is fairly nested, so you'll need to summon values farther down using the dot notation on the object. Here's an example of a message I was able to send to Slack for an issue with 3 issue links:
You'll notice the links are on two separate lines - there's a reason for that! Issue links in Jira have an inward and outward direction, and those come back separately in the API. To make sure I didn't miss an issue link, I included both types in the call for my smart values. Here's the message source for my example:
Issue {{issue.key}} is now for your review!
Links:
{{issue.issuelinks.inwardIssue}}
{{issue.issuelinks.outwardIssue}}
Hopefully that helps clear things up! Adding .inwardIssue and .outwardIssue to the issue.issuelinks smartvalue should get what you're after.
Daniel
Louis_Zhang
March 31, 2020
Wow, I'll try it out right now. Many thanks.
Like Corentin Musart likes this
Stephen Doyle
June 4, 2020
@Daniel Eads That's really cool. Is there a way to pull additional data from the issue link?
For example, the name and URL of a web link.
Like # people like this
Tom Williams
June 19, 2020
@Stephen Doyle  have you found a solution your question yet?
Like Joe Sapinoso likes this
Joe Sapinoso September 2, 2020
Hi @Daniel Eads , I tried your suggestion above in order to copy a field into another, but this was the result:
 2020-08-28 12_52_33-[IT-23311] Update ADCM-Hotfix jira fields - Atlassian JIRA and 6 more pages - Wo (1).png
Is there an adjustment you can recommend wherein the highlighted just shows the Ticket Name as opposed to the URL?
Daniel Hostrup Eriksen
@JoeYou should be able to append the property to the string, like:
{{issue.issuelinks.inwardIssue.summary}}
Talha Aras
And if u want it, you can reach url by {{issue.issuelinks.inwardIssue.url}}
