How to control work flow between 2 jiras
Venkatesh Bn
Hi All,
1)Have synchronizing jira-1 and jira-2 via emails.But this synchronization done when there is any issuecreate and issueupdate
2)Here is problem:when issue is closed/reopend/fixed in jira-1 then also email are going to jira-2,so work flow is change in jira-2,i don't want email related to closed/reopend/fixed
For your information,using gmail smtpmailserver
Give me solution
Nica Huestegge
It seems to me you have to change the Notifications in https://confluence.atlassian.com/display/JIRA050/Creating+a+Notification+Scheme
Nic Brough -Adaptavist-
June 25, 2012
You need to go over your notification schemes VERY carefully if you've got two-way emailing going on. You need to make sure that the dummy users you are using for import and mailing have their "email me on my changes" flag set "off" and that the emails going out are appropriate.
