How to fill custom field value while creating a issue through REST API
Anshul Mittal
April 14, 2023 edited
"customfield_123": {
"required": true,
"schema": {
"type": "option",
"custom": "com.atlassian.jira.plugin.system.customfieldtypes:select",
"customId": 123
"name": "Field_123",
"key": "customfield_123",
"hasDefaultValue": false,
"operations": [
"set"
"allowedValues": [
"self": "https://xyz.atlassian.net/rest/api/2/customFieldOption/1",
"value": "abc",
"id": "1"
"self": "https://xyz.atlassian.net/rest/api/2/customFieldOption/2",
"value": "pqr",
"id": "2"
I want to fill above field while creating issue using REST API in spring.
IssueInputBuilder issueBuilder = new IssueInputBuilder(projectKey, issueType, issueSummary);
issueBuilder.setFieldValue("customfield_123", 1L);
issueBuilder.setFieldValue("customfield_123", "1");
issueBuilder.setFieldValue("customfield_123", "abc");
I have used above variations and all giving the same error below.
Caused by: RestClientException{statusCode=Optional.of(400), errorCollections=[ErrorCollection{status=400, errors={customfield_123=Specify a valid 'id' or 'name' for Field_123}, errorMessages=[]}]}
What should be approach here?
Bill Sheboy
April 15, 2023
Hi @Anshul Mittal -- Welcome to the Atlassian Community!
First thing, you might also want to look in the developer community for questions like this one: https://community.developer.atlassian.com/
Back to your question...and I have not tried this to verify...
That second parameter to setFieldValue() can be a ComplexIssueInputFieldValue, and so you would need to compose it as needed.  Your custom field appears to be a single select field and so you would need to provide either the id or name attribute for selection.
atlassian, out of office, loom, confluence, async collaboration, meeting recaps, remote teamwork, team alignment, knowledge sharing, AI-powered notes, productivity tools, workforce continuity, teamwork collection
Put your meeting notes on autopilot with Loom + Confluence
AI-powered meeting notes keep work moving even if you’re out of the office. Enjoy your well-deserved time off and return refreshed, confident you’ll catch up in no time.
Learn more
