  • Community
  • Q&A
  • Jira
  • Questions
  • Is it possible to copy a flow/intent or create a template for this when using virtual service agent?
Gunnar Derk
June 6, 2025
I want to be able to copy a flow or intent that I created in order to reuse it rather than starting from scratch each time, a template that I can design would be useful as opposed to the ones generated by Jira. I am not seeing any of these features and just wanted to check to see if anyone had any input.
4 votes
Rohitha Devi Pullepu
Hi @Gunnar Derk
You're right—Jira doesn’t currently support a native way to create a reusable “flow” or “intent” template in the way you're describing (like cloning request type configuration, forms, automation, etc., in one go).
Unfortunately, there are no alternatives for this as of now
