  • Community
  • Q&A
  • Jira
  • Questions
  • Is there a way to hide released versions of a project in a Single Version Picker custom field?
Ryan Grimard January 18, 2012
When editing the custom field, I see "Version options:All versions available for the project of the issue". How are these options set? I can't find the documentation on this.
Jobin Kuruvilla [Adaptavist]
February 2, 2012
You might want to create a new custom field type. It is not possible out of the box in JIRA.
You can also modify the template for version picker and restart JIRA. Remove the following from edit-version.vm under WEB-INF/classes/templates/plugins/fields/edit:
        #if ($releasedVersion && !$releasedVersion.empty)
            <optgroup label="$i18n.getText('common.filters.releasedversions')">
                #foreach ($option in $releasedVersion)
                    <option#if ($selectedValues && $selectedValues.contains($option.id.toString())) selected="selected"#end value="$option.id">
                        $textutils.htmlEncode($option.name)
                    </option>
                #end
            </optgroup>
        #end
Remember, if you do this, you will have to do this for every JIRA upgrade!
Bhushan Nagaraj
September 20, 2012
Can released versions be hidden only for "Fix Versions"? We do not want users to select a fix for a version that has already been released.
Ryan Grimard February 2, 2012
Anyone else?
Bhushan Nagaraj
September 24, 2012
If its a version picker custom field, and you would like to hide released versions for a single field, try this
1. Edit the file in WEB-INF\classes\templates\plugins\fields\edit\edit-version.vm
Replace
#if ($releasedVersion &amp;&amp; !$releasedVersion.empty)
            &lt;optgroup label="$i18n.getText('common.filters.releasedversions')"&gt;
                    &lt;option#if ($selectedValues &amp;&amp; $selectedValues.contains($option.id.toString())) selected="selected"#end value="$option.id"&gt;
                    &lt;/option&gt;
                #end
            &lt;/optgroup&gt;
#end
with
#if($customField.id != '&lt;YOUR CUSTOM FIELD ID&gt;')
                    &lt;/option&gt;
                #end
            &lt;/optgroup&gt;
        #end
#end
I am still trying to hide the released versions from the "Fix Versions" system field but unable to do so. Any help would be appreciated.
Cheers
Bhushan
Renjith Pillai
January 19, 2012
I guess the archived versions are not shown in version picker fields.
Ryan Grimard January 19, 2012
Agreed, but my requirement was single-pick.
I have two single version picker custom fields. In one of them I'd like to only show unreleased versions.
Renjith Pillai
January 19, 2012
Actually the affects versions and fixversions (the standard fields) exactly serve these purpose.
