Hi Team,
I am working with JIRA DC and Automation for JIRA. I am copying over the work logged in a Task to its parent Epic using the below expression.
{{#=}}{{worklog.timeSpentSeconds}}/60{{/}}m
Appears to run fine for Work logged with single decimal places. e.g. if I log 1.5h, it gets logged properly.
When I log 1.52h on the task, it ends up on the Parent as 15.2h (although in the log i see the value as 1.52) for my expression above. Not sure if this a bug in Automation for JIRA.
Has any of you also run into such a situation? Any leads how to overcome this?
Thanks & Regards,
Janaki.
First thing, I am using Jira Cloud and not Server so my observations may be wrong.
I have noted that with JQL and other things in Jira, the time fields have discrete units of measure limits, probably related to the numeric conversion of values to whole minutes. For example:
1.5h and 1.55h convert to an even number of minutes and 1.51h does not. So I wonder if this is leading to the issue.
Hi @Bill Sheboy ,
Thank you for replying. Couldn't understand what you are inferring / suggesting here. Can you please let know if you are suggesting that I have to adapt the math expression / is this a handling of Automation app?
Thanks & Regards,
Janaki.
Hello!
I wonder if Jira is incapable of handling a value which does not lead to an exact number of hours, minutes, seconds; this may be a binary/decimal/time representation and conversion issue. That is, when you divide by 60 it is no longer possible to represent the value as a time, and so it cannot be stored in that field type.
You could contact the support team to confirm this behavior ( https://support.atlassian.com/contact/#/ ) or try truncating/rounding the values after the division.
