The configured Max Jira Project Key and Project Name Size is same for Jira Software and Jira Service Management Projects or is there any different configuration option for JSM to define these values?
Hi @Abhijeet Kale ,
By default, project name length is 80 and Project key is 10. It can be modified in
Select > System.
Select General Configuration > Edit Settings.
Select Update when you're done.
All the Jira application configurable items are listed in https://support.atlassian.com/jira-cloud-administration/docs/configure-jira-application-options/
@Rilwan Ahmed Thanks for the reply, yes I am aware the default configuration settings, but want to know if this applies to all the Jira applications like Jira Software, Jira Service Management, Jira Work Management, etc based on the document it looks like that, but can you confirm the same?
