Hello everyone, I am looking for a solution in order to be able to modify the characteristics within a ticket and that it also modifies the characteristics of the linked ticket.
If anyone have the answer I take it.
Hi Edgar,
Check out the Automation template library for examples of Automation rules to sync between tickets: https://www.atlassian.com/software/jira/automation-template-library/most-popular
You can read more about using Automation here:
https://www.atlassian.com/software/jira/guides/expand-jira/automation
Charlie
Thank you for the answer but even with this is by doing different tests on my side, I still can't do it, if you have other ideas I won't say no.
