Problem with Eclipse and JIRA Subversion Tab
Ish Fad September 7, 2014
Hi
I have integrated Eclipse and JIRA. Both seem to be working fine. I can see Subversion tab. when I open an issue. When I make change to code in Eclipse and commit to svn with the project key KT-1022 in a commit field. eg My project key is KT, so have created issue with the id KT-1022.
But when open Subversion on this issue in JIRA, I don't see any information related to issue.
Please can some one advice.
ish
Boris Berenberg
September 8, 2014
Does the subversion tab update if you commit to SVN from outside of Eclipse? It sounds like the SVN integration in JIRA is not correctly configured. Please take a look at: https://ecosystem.atlassian.net/wiki/display/SVN/Subversion+JIRA+plugin if you are using the SVN plugin or at: https://confluence.atlassian.com/display/FISHEYE/Subversion if you are using Fisheye.
