Hello community,
I'm using the former codebarrol app "Automation for Jira". Now I have following requirement for our monthly settlement process:
I creating scheduled tickets, which works fine. The issues are created on the last day of the month. Regarding the created date the summary should look like this:
Monthly settlemeant - mm-yyyy (from created date)
I tried to implement that with smart values, but it doesn't work. Is there any other solution for that?
I used this expression: {{issue.created.format("MM/yyyy")}}
Thanks in advance for your help.
Best regard,
Nicat
Hi @Nicat Nagiyev ,
I think you can not get the "issue.created" value inside create issue action. Because at the time of "issue.created" function call, issue has not created yet. Instead of "issue.created", try using "now".
{{now.format("MM/yyyy")}}
Hi Nicat,
I was playing with this and I think I found a solution but TBH it is odd that you have to do this to me. So I created two actions in the rule:
LMK if this works.
Hi Nicat,
Can you share some screenshots of what you have and what is not working?
Validate your expertise in managing Jira Service Projects for Cloud. Master configuration, optimize workflows, and manage users seamlessly. Earn global 🗺️ recognition and advance your career as a trusted Jira Service management expert.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
