  • Community
  • Products
  • Jira
  • Questions
  • A project in JIRA has only few fields. Why do we not have CUSTOMER NAME as one of the fields. I added some custom fields using HTML but is there a better alternative?
shampa
September 11, 2012
Jobin Kuruvilla [Adaptavist]
September 11, 2012
Custom fields are supported only for issues in JIRA. For project you will have to develop some plugins or use the existing plugins like metadata plugin.
Guillermo _DEISER_
Hello Shampa;
We developed a plugin to meet this requirement. Profields can achieve what you want and many other needs. We have just released Profields version 2.0 you can see our landing wiht the most relevant features (all versions).
http://www.deiser.com/subject/landing/profields/
Of course if you try it, you can also send us your feedback and your specific requirements to:
http://www.madeira20.com you can sign up and create issues with your questions.
With Profields 2.0 now it's also possible to execute JQL queries using the attributes created with the plugin. Although the JQL box works only with issues, you can combine the filter with some gadgets of JIRA.
