×Hello,
how to activate SSL Auto redirect to HTTPS in Servicedesk, Bamboo and Jira. Now at the moment it is not active and i would like to activate it.
Thanks for any help.
For every application process might be a little different. For example this is documentation for Fisheye (that you do not need but might give you an idea)
Easiest way is to set up Reverse Proxy and set Rewrite Rules that would automatically redirect to HTTPS. Example info here:
Please check out this documentation.
