Active / Passive Jira System - Licensing?
Deleted user March 27, 2012
Dear all,
if i want to set up an active /passive jira system, where the database is in a metro-cluster and only one jira instance is active, how many licenses do i need to implement this setup? I guess, i only need one license, because only one machine is online. Is this correct?
Best regards
Dirk Küver-Christen
Andrew Frayling
March 27, 2012
Hi Dirk,
Just the one license would be needed as you can use a free developer license for the standby. Have a look at http://www.atlassian.com/licensing/purchase-licensing#licensing-9 for details:
"Developer licenses can also be used for non-production installations of our software deployed on a cold stand-by server."
Hope that helps,
Andrew.
Hi Andrew,
many thanks, that helps.
Best regards
Dirk
