I have created a few custom fields using an API call.
These fields were created successfully and I can view them on my Jira dashboard in Issues > Custom Fields.
When I call another API to create an issue within a project, I want to assign values to these custom fields.
I was able to get the custom field ID from Jira eg. customfield_10082
When I now call the API to add an issue with a structure like this -
"fields": {
"project":
"key": "ProjectKey"
"summary": "This is a Test Issue ",
"description": {
"type": "doc",
"version": 1,
"content": [
"type": "paragraph",
"content": [
"type": "text",
"text": "Test Description"
"customfield_10082": [{"key":"This is my custom field"}],
"issuetype": {
"name": "Task"
I get an error that says -
"Field 'customfield_10082' cannot be set. It is not on the appropriate screen, or unknown."
When I edit this field on Jira, I added it to all the 3 available screens -
Default Screen
Workflow Screen
Resolve Issue Screen
However, even after adding it to the 3 screens, I get the above error and I am unable to add the custom field to my issue.
I have seen some older threads on the same issue where it was mentioned that it was not possible to add these custom fields to a screen / project.
Eg. Here
Is there any way in which I can achieve this?
I have created the custom fields previously, I now want to create an issue, and while creating it, add values to these custom fields in the issue.
Any help is appreciated.
Thanks !!
Hi @Maulik Panchal ,
The screens are a „ordered display list“ of fields. Those screens can then also be added to screen schemes which define which screen appears on a special operation (view, create, edit).
Could you confirm that you can see the field when you create a new issue manually within jira?
Best
Stefan
This custom id might be already exist if you can try with some other Id. I think that will work. I am creating from Postman and I am able to successfully achieve this activity.
