×Hello Jira Users,
I have a requirement where Jira should auto create tickets in project B based on the component vale of Project A.
I know we can auto create tickets in Project B from Project A using post-functions plus Script Runner add-on but I want this to happen based on the component value selection, is this possible?
For example if a user creates ticket in Project A for a component value TEST only then Jira should create a ticket in Project B else it shouldn't. Please advise, any help would be greatly appreciated on this. Thank You.
Hi @Teza
This should be possible. Just make a Listener, fetch selected components, and have an if-statement check if the component TEST is selected.
Cheers!
@Mathis Hellensberg Thank You very much for your advise on this issue, would it be possible for you to walk me through the steps on achieving this?
Thank you for sharing the above solution.
If I've more than 100 Components and more than 100 Jira projects.
How can create Jira issue in a specific Jira project based on the selected component?
Hi @Teza ,
You can do this with the Automation for Jira addon as well. It is really easy to put together a rule that would do this. For example:
This rule will create a ticket in another project when a ticket with a component of Support Question is created in another project.
Simeon
Hi Simeon,
Why not use a mult project custom field?
It will help you with expansion of your projects
Thanks, @Najjar _Innovura_ but this includes buying a new add-on, any other solution that you can offer without the need to buy new add-on's?
