Hello all,
I have received the following request from a customer.
"If only DCPA/SONS tickets are linked to an ITS issue with security level PO, the ITS ticket should be closed when the last DCPA/SONS ticket linked to it is closed.
As far as technically feasible, the final comment transmitted when the DCPA/SONS ticket is closed should also be transferred to the linked ITS ticket (but only this comment and not all comments from the sub-tickets in general)".
Unfortunately I'm totally stuck on how to do the trigger, the check for the last closed ticket and the comment. Can anyone give me a hint here.
Thanks a lot already, greetings,
Max
Hi Max,
Here's an idea. To make it simple, you can try to create three different rules:
That's the first idea that came to my mind. I hope it will give you some new ideas.
