Automation - 'Only include issues that have changed since the last time this rule executed' checkbox
Humberto Gomes
February 11, 2021
Hi
Some of my automated rules are doing nothing. The log says:
I can remember this option, but can't find the box to deselect:
Where is the box?
What I'm doing wrong here?
Humberto
wwalser
February 12, 2021
I'm investigating this. A workaround for the moment: clicking on the text associated with a checkbox is typically sufficient to toggle the checkbox. Try clicking the text then saving the rule. You'll know if worked if the rule starts executing on all relevant issues.
Edit: didn't realise this was for A4J Server. I'll check with that team to see if they have news.
Humberto Gomes
May 12, 2021
Hey,
Many thanks for all updates.
This is not fixed yet:
[SRJIRA-5012] Checkboxes in Automation for Jira became hidden with SR enabled - Product Support (adaptavist.com)
Lastest comment "... hard to fix...."
Jamie Echlin _ScriptRunner - The Adaptavist Group_
There is an explanation of the problem here:
https://productsupport.adaptavist.com/browse/SRJIRA-5012?focusedCommentId=405556&page=com.atlassian.jira.plugin.system.issuetabpanels%3Acomment-tabpanel#comment-405556
Anyway, the fix for this should be released on 19 May 2021.
There is a release candidate version if you want to check it fixes the problem in your non-production environments, in a following comment.
Gyorgy Dani-Rauf
As a temporary workaround while you are editing the rule and you can't see the radio buttons and the checkbox, turn on the Web Developer Tools (Ctrl+Shift+I or F12) and Inspect element.
<input class="radio" type="radio" name="executionMode" id="jql" value="jql" checked=""> or <input class="checkbox" type="checkbox" name="onlyUpdatedIssues" id="onlyUpdatedIssues" checked="">
and uncheck clip (in Chrome I had to uncheck height and width as well) under element, so you can see the selected values and make the necessary changes.
Kai Becker
Having the exact same issue.
  • Jira 8.5.9
  • A4J 7.26
I can confirm that its still working in our second instance, with the same Jira version but A4J 7.1.16.
Humberto Gomes
February 18, 2021
Thanks for sharing
Like John Funk likes this
Humberto Gomes
April 30, 2021
still not solved by the script runner team.
Vikas Pandey
April 8, 2021
Okay I fixed this for add comment once check box, in comment add action using following script.
<script>
jQuery(document).ready(checkBoxRenderer);
function checkBoxRenderer () {
if($("#iFrameResizer0").contents().find("#addCommentOnce").is(':visible')){
    if($("#iFrameResizer0").contents().find("#addCommentOnce").val()){
   $("#iFrameResizer0").contents().find("#addCommentOnce").css({'clip': 'auto', 'height': '15px', 'width': '15px'});
}else{
//do nothing
console.log('do nothing');
  } else {
    setTimeout(checkBoxRenderer, 3000);
</script>
 If you are seeing this with other checkboxes too, inspect the element and right click the HTML to copy the selector and replace the script above with existing selector >> #addCommentOnce, on all three lines.
It is breaking because some plugin is pushing clip(0,0,0,0) attribute to check box CSS:
Humberto Gomes
March 15, 2021
Still waiting for the Script Runner fix version
Humberto Gomes
March 10, 2021
Still waiting for the Script Runner fix version.
alex February 18, 2021
Same issue with Jira 8.5.11, Automation Lite 7.2.1
Humberto Gomes
February 25, 2021
Do you have the app:
Script Runner?
AviGhosh
March 8, 2021
Yes, the issue is due to the script runner plugin.
You can downgrade to the scriptrunner version 6.15 to resolve the issue
Like # people like this
Humberto Gomes
February 11, 2021
What we know at this moment:
  • I'm the JIRA admin. (same problem)
  • 2 different browsers tested. (same problem)
  • Both with Cache cleared. (same problem)
  • Creating a new rule  (same problem)
  • Asked to be done by other Jira admin (new laptop, network, browsers...) (same problem)
Versions:
  • Automation for JIRA version: 7.2.6
  • Jira Server version: 8.5.3
What next?
It's a bug from this version?
Humberto
Humberto Gomes
February 17, 2021
Answer from Atlassian Support:
try the below options:
  • Disable and enable the Automation for Jira to check if this resolves the issue
  • Clear plugin cache
  1. Stop the JIRA instance.
  2. Delete JIRA_HOME/plugins/. bundled-plugins and JIRA_HOME/plugins/. ...
  3. Restart JIRA.
Humberto Gomes
February 18, 2021
Update:
  3. Restart JIRA.
Did NOT resolve the issue.
Humberto Gomes
February 24, 2021
Update:
The issue is not solved.
Steps performed:
Set up JIRA in Safe Mode (disabling all rules)
 - Enable Jira Automation - Box is there
 - Enable all other apps, one by one, and testing always between enabling.
    Box disappears when enabling Time To SLA app.
Safe mode again.... same procedure...
 Box disappears after enable Time Status app.
Safe mode again... same procedure...
Box disappears after enable Plans (old portfolio app)
Box disappears after Excentia app.
The behaviour is not the same, so sent to Atlassian the report and zip file.
Waiting for new troubleshooting steps.
Humberto
set up JIRA in Safe Mode using the MAnagem apps menu,
Jack Brickey
Has Support responded to your updates?
Humberto Gomes
February 25, 2021
Update:
Issus is not Solved.
Steps performed:
  • backup Jira
  • backup automation rules (export all rules )
  • uninstall A4J
  • ensure the plugin cache is cleared by following the below steps:
    Delete JIRA_HOME/plugins/.bundled-plugins and JIRA_HOME/plugins/.osgi-plugins ( just these two folders!)
    Restart JIRA.
  • Reinstall A4J latest version 7.2.8 again.
Some notes:
- Backup Jira is only for just in case...
- Backup Rules did but not needed to import.
Jack Brickey
Thanks for keeping this thread updated @Humberto Gomes . This sure seems to be an ugly bug. 🤔
Humberto Gomes
February 25, 2021
There is a temp fix (already done here).
Go to Safe Mode. (full safe mode)
Enable AFJ.
  active/deactivate the box  (it's available) as your need.
Back to normal setup.
  the box will be available again but isn't configured.
The box still not visible for new rules and we can't go to "safe mode" every time.
Jack Brickey
Humberto Gomes
February 25, 2021
For now, with more tests, looks like the issue is in the app: Script Runner from Adaptavist
Starting with version 6.16
My findings:
ScriptRunner version 6.14 - No issue in A4J
ScriptRunner version 6.15 - No issue in A4J
ScriptRunner version 6.16 - issue in A4J
ScriptRunner version 6.17 - issue in A4J
ScriptRunner version 6.18 - issue in A4J
ScriptRunner version 6.19 - issue in A4J
ScriptRunner version 6.20 - (latest version available) -  issue in A4J
Like Kai Becker likes this
Kai Becker
Can confirm that. The instance on which it still works uses ScriptRunner 6.05. None working instances uses ScriptRunner 6.16
Humberto Gomes
February 25, 2021
Update:
Case raised to ScriptRunner owner:
"Thanks for reaching out to Adaptavist Support!
We are sorry you are experiencing this issue. There is a fixed Bug report for this here: SRJIRA-5012. It is currently in 'Awaiting Release' Status, meaning the Developers are finalizing the fix for public release."
Like Jan Herzog likes this
John Funk
Hola Humberto - it's probably not there because you are not a Jira Administrator and the rule is a multi-project or global rule. You can get an Administrator to update it to uncheck the box,
Humberto Gomes
February 11, 2021
I'm the Jira Administrator.
John Funk
Are you using the Free Lite version or the Paid Version?
Humberto Gomes
February 11, 2021
Paid one.
John Funk
I would definitely open a support ticket with Atlassian.
Please post the resolution back here so we can close this one out.
Hana Kučerová
Hi @Humberto Gomes ,
yes, I think this is the right place. The checkbox is missing, but I believe it should be there.
If you try to delete the trigger and add it again, does the checkbox appear?
Jack Brickey
Or try adding a new rule
Humberto Gomes
February 11, 2021
New Rule:
Same Problem
Already done:
Browsers: Chrome, Edge
All with clear Cache.
Jack Brickey
This seems to be a duplicate and yet under a different member - Jira-Automation-Only-include-issues-that-have-changed-since...
Humberto Gomes
February 11, 2021
Yes, it's duplicated.
Now I can understand why could not see/find the first one.
Humberto
Jack Brickey
can you try to add a new rule just as a test to see if the checkbox is there?
Humberto Gomes
February 11, 2021
Already done. Same issue. the box is not there.
Jack Brickey
thanks for the update. seems like it is time to reach out to the Atlassian for support
Jack Brickey
p.s. I have inquired thru my other connections seeking other Server A4J users to see if anyone is experiencing this. Maybe they will chime in here FWIW.
Like Dave Liao likes this
Hana Kučerová
I've just tested it using AfJ 7.2.6 and Jira Software 8.8.0 and I was able to use the checkbox. So it seems to me it is not connected to the latest version. As the others said - it will be the best to reach out to the Atlassian, it is really strange.
Bill Sheboy
February 11, 2021
Hi...  Did you notice that the radio buttons immediately above, for other options, also appear to be missing on that view?
