Automation Rule: Clone Required Fields to External Project
ayoung
Hi there -
I am writing an automation rules in Cloud Version of Jira Work Management to clone a story to an external Software Project board if conditions are met.
Tested this on a test board and all went well.  The live board we'll be posting TO though, has a required field.   The FROM project has this field but its not required.
_________________________________________________________________________________________
When running the automation we are receiving this error in the audit log:
CLONE ISSUE
Found multiple fields with the same name and type: .
Requirements (com.atlassian.jira.plugin.system.customfieldtypes:textarea)
Error creating issue
Requirements is required. (customfield_10682)
The custom field ID's being referenced are:
FROM Board: "Requirements" is  CustomField_10918
TO Board: "Requirements" is customfield_10682
Basically when cloning this issue I need to copy the contents of 10918 to 10682 in the destination project.
This is currently what I have set for the automation cloning rule:
It generates the error seen above in the audit log.   Any help? Maybe I need to use the Additional Fields section to address this?
Kseniia Trushnikova
Hi @ayoung,
You can copy the field values using the Additional fields section:
"fields": {
"customfield_10682": "{{issue.customfield_10918}}"
The other solution is to change one field name to a different one or to use one field with two different contexts for each project, then the rule will run without error.
ayoung
Was able to get help from a developer friend who was more familiar - This fixed the error reports:
