Automation for Jira - Based on duedate
Paula Pokusa August 24, 2020
I am trying to create a new rule in our Jira instance. If the due date for a ticket is 3 months or less I would like to create a rule that assigns a label to the ticket. Not sure if this is possible or how to go about it, any help/guidance would be appreciated!
John Funk
Hi Paula - Welcome to the Atlassian Community!
You can create a Scheduled trigger with Automation For Jira. Have it run daily (every one days).
Then use the JQL Condition for the due date query.
Then New Action for Edit Issue to update the Labels field.
John Funk
Hey @Paula Pokusa  - Did you give it a try? Did it work?
sierra tiktas April 27, 2023
 You will need to have this run everyday.
So as you see in the picture above you will want to have it scheduled daily example (3).png
I added the JQL in the picture to show you have to search for three months or less
Then add your label.
Yvan Martin
August 27, 2020
Hi @Paula Pokusa
Developer from Automation here.
As @John Funk mentioned you'll need to create a scheduled rule with a JQL statement to find due date less than 3 months and update the labels field.
Here is an example rule configuration I did, that will hopefully do the job. You can click "validate JQL" to try the query and see which issues will be picked up:
