I need to compare version name with 2 values, so that rule is executed if version name contains either value 1 or value 2.
Is it possible or I must create second "else if" condition which would contain exactly the same action?
It depends on what type of field it is.
I would suggest checking doing this with the Isuse Fields condition first. Depending on the field, it may let you check if the field is ONE of TWO different values you provide, which would give you what you need.
If that is not possible, then yes, proceed with an else if condition.
