Automation for checkbox field?
Gem Sung September 27, 2019
Hi, automation newbie here looking for some help.
Looking for a way for Jira to autocheck from a field of checkboxes based on the test present on the issue.
e.g. Text "disconnect" is present in description and/or comment which will tick the "disconnection" checkbox in a field.
There is a big list of checkboxes in this field, and I want to automate finding several keywords and tick any and all relevant checkboxes.
I also don't want it to to check for a keyword, find one, and stop the process, which is what I'm currently stuck with. Image attached.
Triggered when a new comment is added.
Caryn Wilson March 11, 2020
Did you find a solution for this @Gem Sung ?
I've got the same problem where the last condition met determines the checkboxes ticked.
fran garcia gomera
September 27, 2019
Why the otherwise if you want every rule is checked?
diferent if blocks will do the job if conditions are not excluding amongst them
  1. when...
  2. If block (condition 1)
    1. do something
  3. if block (condition 2)
    1. do something different
  4. if block (condition 3)
    1. do another thing
Yes, that's what I am TRYING to do, though the JIRA UI adds the 'otherwise' and I'm not certain how to change that to an IF.
Any ideas? The interface isn't clear on if this is even possible.
My other option would be to create a separate rule for each condition...
Just tried this and the separate rules untick the checkboxes previously ticked...
