×Hi!
I need to create subtasks from values in a customfield. The known way is to create branches, where i can check - does the customfield contain Value1? And create subtask, if it contains.
But if i have a lot of values, this way is too hard.
Is there any way to create For-Each loop? For each value in customfield create subtask.
Thank you!
as far as I understood you described 2 different scenarios because the first one would obly be an „if“.
There is a special „for each“ branch that would create a subtask for each value while iterating over a field or a list.
I recently answered a question similar to your requirement. See the following link:
Hope this is helpful.
Best
Stefan
AWESOME!!! Good to know you got that working 💪💪
Best
Stefan
Stefan,
This is very helpful. Thanks I too was able to solve my issue using above. Appreciate it
Great to hear my answer was helpful and you got that working.
Thanks for the feedback.
Best
Stefan
