Hi guys
I have set Teams in JIRA, meaning each user is part of one team. I want to create Jira automation so that if a ticket is assigned to someone, the team field will be updated to that team automaticaly.
For example, Jon from team Dev
If a ticket was assigned to Jon, the team field will automatically be updated to 'Dev'
Can you suggest on how to do that? hopefully with no special scripts :)
Thanks!
Not really a lot of scripting but a lot of iterations of you want to make it work. You would have to identify each team member on the assignee of an automation.
If assignee = Jon then update Teams field to Dev.
If you have a lot of users in Teams "Dev" it would be very tedious.
I would suggest just going the group route which can be searched via SQL.
