Hi
I have some automation rules for a software project, these rules should change fields upon ticket creation. However, the audit log shows no event other than configuration changes.
The rules are project specific and confirmed within the right project scope.
Rules are triggering normally for other projects.
I suspected a missing Issue Created event, and added this to the transition to status: New, but no luck.
Are there other logs that can tell me why this is or isn't happening?
This has been solved. It was a long week and I was working with many workflows. I added Issue Created event to the wrong workflow.
Added Issue Created event to the correct workflow and automation is now firing correctly.
Hi @Marius Skoglund ,
Does the rule work if you remove the condition on Status?
Can you add a screenshot of the Rule Details?
Is the Epic created by a user or by another automation rule?
If it is by an automation rule look at 'Allow rule trigger' in rule details
Regardless of your question, my advice is to see if you fill in a specific custom field when creating an Epic and use "Field Changed" (on create issue) as a trigger with this custom field. Then the rule only goes off at the intended Epics. Saves a number of unnecessary rule starts.
Regards, Marco
