Automation "Comment issue" is not workin with another automation
Igor Titov
Hi!
I have an automation rule A that creates a new task in the project.
And there is an automation rule B that creates a comment about creating a new task.
Problem: A comment is not created if the task was created through automation A.
If I create a task manually in the project via the "Create" button, then the rule works and a comment is created.
Help, please!
2 accepted
Walter Buggenhout
Hi @Игорь Титов,
Check the rule details page of your automation rule that should add the comment. At the bottom of that page, you can enable a check box so the rule responds to actions triggered by other automation rules:
Screenshot 2024-08-16 at 13.32.16.pngMy guess is this check is currently not enabled and so your rule does not respond to other automated actions.
Hope this helps!
Jack Brickey
Hi @Игорь Титов , you need to be sure to select the checkbox in rule B details to allow the rule to be triggered by another automation rule.
Igor Titov
Thank you both!
