Hi!
I'm trying to create lots of issues in bulk via External System Import from a CSV. I have an automation rule to automatically create particular subtasks when a particular parent is created (shown below).
Can anyone tell me why my rule isn't running? It works when I create an individual issue in jira but not when importing in bulk (it doesn't even come up in the automation rule log, ie it's not failing, it appears as though it's just not running).
Hey @Hayley Rodgers
Looks like this is a bug as recorded here https://jira.atlassian.com/browse/MIG-378
Seems like while bulk upload via csv issue updates event is fired instead of issue created event, hence automation rule is not triggered.
As workaround try writing an automation with "Scheduled" on trigger for short interval period and add the condition and action.
Vishwas
Ah I see!
That workaround works, thanks Vishwas :)
Glad to hear it worked !!,
Please feel free to upvote , Accept answer if it solved the issue :)
I found using this import https://yourdomain.atlassian.net/secure/BulkCreateSetupPage!default.jspa?externalSystem=com.atlassian.jira.plugins.jim-plugin%3AbulkCreateCsv
works well! (On your project, Create / Import Issues)
Try it!
