Hi ,
can someone tell me if counting comments in an issue/ticket is possible by automation?
If yes, please do share the steps
Hi @Hermie Chiu ,
Welcome to the community!
Automation has list smart values for comments, so you would be able to get the amount of comments using:
{{issue.comments.size}}
See more info here.
You can use this value in a field or something, and you can pick any trigger you want (on adding new comment, on update, manual if you only want an update on request,..)
kr,
Tessa
HI @Hermie Chiu
@Tessa Tuteleers is right. I'm just puzzled what will this number provide?
It just will tell the issue has 7 comments, I can read the comments as well an see th! there are that many comments.
Just curious!
