Automation to reopen issue marked as done
Fergal Kelly September 25, 2020
Is it possible to create an automation process that:
  1. reopens issues of a certain description e.g. "monthy audit"
  2. within a specific project e.g "recurring issues"
  3. that have been closed 25 days or more,
  4. sets due date to 30 days from when it was originally closed.
thank you
Fergal
Jack Brickey
yes i think you could swing that. Have you attempted this yet and if so are you stuck?
Thanks for your reply Jack.
I have looked at it but only gotten as far as setting the schedule to run the rule once a week, the got stuck at the JQL as wasn't sure how to do a search for the different items I have listed. If you could help with this, I will then attempt to do the next part and see how far I can get with the component.
thank you
Jack Brickey
would have to play w/ it a bit but something like...
project = "recurring issues" and description ~"monthly audit" and resolutiondate <= startofday(-25d)
thank you Jack, I'm trying it out now with smaller time frames to see if it works. everything after the JQL search seemed pretty straight forward.
Thank you
All works perfectly, thanks for the help
Bryan McMillan
@Fergal Kelly ,
It is indeed possible to accomplish this automation with Power Scripts for Jira from Cprime but only for Jira Server or Data Center.   A script would to be created to implement the functionality you are asking about.
Kind Regards,
Bryan McMillan
Cprime Solutions Architect
Thank you for the reply Bryan, do you know if it is possible to create using the just rules?
Kind Regards
Fergal
FREE
