Hello ---
I am creating Automations to perform the following:
I would like for the process to be:
Thoughts on how to compare an automation to what is currently on a board? Thank you in advance!
Hello Alisa,
If I am reading your requirements correctly, you:
To clone and issue (you could also create an issue, if desired). See how the issues are linked in the "More options".
I am not sure the exact conditions you are looking for, but you can use an if/else block to check for already existing smoketests. If none exist, create a new ticket.
I hope this give you some ideas on how to start on some Automation rules. Please let us know what you think!
Hyrum
Hi @Alisa Johnson ,
Would start looking into if there's any association between the playtest and smoktest ticket. Without some kind of pattern or association, it will be harder to automate and find the smoke test that went along with the playtest.
For example,
if the playtest is link to smoketest upon creation, then you setup an automation to see if there is a link ticket smoke test during the transition to complete. If not, create one. If yes, don't perform any action.
-Ben
