Your timezone. The value is set automatically from your browser, so please only modify if it's incorrect. <br><script language="JavaScript"> <!-- function setCustomerTimezone(){ tzlist = document.getElementById("customfield_10421"); if (tzlist) { if (/CreateIssueDetails.jspa/.test(tzlist.form.action)) {// Value has not yet been set           if (tzlist.value == -1) {  offset = new Date().getTimezoneOffset() / 60; // hours from GMT if (offset <= 0) { tzlist.value="GMT+"+(-offset);  } else { tzlist.value = "GMT-"+offset; }//          } } }}window.onload = setCustomerTimezone; //--></script>We had a similar problem. We had to clean it up in the database and then restart the JIRA instance to get it pick up the change.
