Building an Assets schema - Looking for how others have dealt with the assignment field
Michael Frade
Building an Assets schema - Looking for how others have dealt with the assignment field.
For example, you have a laptop object type and assigned to: is an attribute of laptop. Is it better to have assigned to as a User type or an Object type that references a People schema?
Wondering pros and cons on each path.
TYIA
Kai Becker
Hi @Michael Frade
thank you for your question.
Usually the assignment will be used to identify the hardware and make it selectable in e.g. a customer portal. This is slightly easier in terms of AQL for the custom field configuration when having direct access to the attribute. But the extra link to a user object which then contains the user as an attribute is also feasible.
When it comes to sharing information between two or more schemas, I would tend to create separate user objects. This makes sense for example if you would like to add more data to a user, like software assignments, roles, working hours or anything else that might be located in an extra HR scheme.
Hopefully that helps.
Robert Nadon
I prefer to do the later.    That way all users are associated to the same scheme., espcially if you want to import from say LDAP.
