×I've set up a project space that is collecting issues from clients. They will be triaged and moved to the team that owns resolution. Is there a way I can automate adding a comment when the issue is moved OUT of the initial project space?
I have figured out how to add comments when an issue is moved into the project space with the trigger "issue moved".
Hi @Renee Niewald - If I understand correctly, you're trying to capture when an issue has been moved out of a specific project? If so, it would be the same rule as when a project is moved in scope, but the rule would need to be global. You could do something like this:
{{triggerIssue}} Moved from:
{{changelog.project.fromString}} to {{changelog.project.toString}}
This isn't specific to in/out of scope, but every issue that is moved gets a comment that it was moved along with the source/target projects.
