Cascading drop down problem in internet explorer .second dropdown is loading without selecting its parent value..
In the above image Second level drop down should show please select instead of that it's showing all the values which are depend on the first level dropdown.
Hi Sathish,
We've just reproduced this problem with another customer and the problem is that you will need to enable the XMLHTTP protocol in IE. To do this, navigate to "Tools -> Internet Oprtions -> Advanced tab -> Security section" and then enable the XMLHTTP support.
Hope this helps.
Cheers
You can take a look on this KB
Cheers!
As @Vicky suggested check the compatibility view mode in IE
check this document to troubleshooting client side problems
https://confluence.atlassian.com/display/JIRAKB/Troubleshooting+Client-Side+Browser+Problems
Three things to check:
