Check for a Linked Issue in Another Project Within a "Single Project" Scoped Automation Rule
Haddon Fisher
November 22, 2023
Question
Has anyone found a way, as part of an Automation rule scoped to a single project, to check for the existence of a linked issue in another project?
Context
One of my project admins has a rule which, when a specific component is set on an issue, clones the issue into a new project, and good design would have us check to make sure the cloned issue doesn't exist already.
swear in the past I've never had an issue doing this, but now I see all of the components explicitly stating the scope. I work really hard to keep global rules to a minimum because maintaining 1,600+ people's business logic with 1.5 admins is not feasible, so I really do not want to make this a global rule.
It makes sense to me that single-project rules wouldn't be able to make changes to issues in other projects, but restricting searching seems like a pretty common use-case even within a single project.
2 accepted
Bill Sheboy
November 22, 2023
Hi @Haddon Fisher
There are two-possible solutions for searching for issues in different projects from rules:
  1. make the rule scope multi-project or global
  2. use the Send Web Request action to call the REST API function to perform the issue search with JQL
That second one is not limited by the restriction of project-scope rules.  However with the changes to the packaging model / limits for automation rules, using Send Web Request will count as a rule execution for the limits.
Haddon Fisher
November 22, 2023
Thanks for this idea @Bill Sheboy...I haven't played with the "web request" action a ton, but it sounds like I have a reason to now!
Like Bill Sheboy likes this
Ste Wright
Hi @Haddon Fisher
That's not a new parameter as far as I know - when using a single Project rule, it's limited to the scope of the rule.
To achieve what you're looking for, you'd need to use a multi-project/global rule.
Ste
Haddon Fisher
November 22, 2023
I have some documentation that I originally wrote back in 2021 that makes me think this wasn't always the case on Cloud...the screenshot is cut off so I can't say for certain, but the logic wouldn't work as it's written today unless the rule was set as global and I am 99% sure it wasn't.
I also know this was a "bug" that was only recently fixed on Server\DC.
I'm sort of assuming you are right Stephen Wright _Elabor8_ though that the scope is impermeable. Just hoping someone sees something genius!
Ste Wright
Just for extra evidence, I found a post from 2020 from an Atlassian team member which confirms it is project-specific - see: https://community.atlassian.com/t5/Jira-Software-questions/Getting-a-JQL-from-another-project-in-automation/qaq-p/1459658#M95623
Ste
Haddon Fisher
November 22, 2023
Wild! Have to look through this rule to see if I can figure out it's deal then. And maybe get my brain checked.
Like Ste Wright likes this
Colin_Turner January 24, 2025
Maybe you could use a smartvalue comparison to see whether {{issuelinks.outwardIssue.project}} is equal to {{issue.project}}?
FREE
