Confluence Article Suggestions in Jira issue view
nithyasree.skm-ext
September 24, 2024
Hi, I am trying to bring up Confluence article suggestions in Jira custom field in Issue view.
Michael Yaroshefsky - Visor for Jira
Hi @nithyasree.skm-ext there's some plugins you could use to add a script that would make this possible (like Scriptrunner or Automation for Jira - just to be clear I'm not affiliated with either of these plugins).
That's probably the neatest way to create a solution that you can rely on.
I recommend taking a look at some of the automation plugins that are available and using a trial version to see if they work as a solution for this. Most have some form of free trial so you can experiment away.
Hope that helps?
nithyasree.skm-ext
September 25, 2024
Thanks for the Recommendation Michael, I will check on it.
