the relation of 2 issues are parent/subtask. I'd like to copy values from parent to the last step of subtask. so if the summary of subtask contains 'contract 05', then copy the values to this issue. The automation I set couldn't work, the audit log shows nothing.
For an automation question like this, please consider posting images of your complete rule, any action details, and of the audit log details showing the rule execution. Those will provide context for the community to offer suggestions to help solve the problem. Thanks!
Try this one
In the "edit issue" choose the filed that you need from the dropdown and then by clicking on the three dots choose copy from
After you need to set it to parent issue
Save and done :)
