Creating JIRA issues from Confluence with custom required fields
Alex Kleshchevnikov
May 22, 2013
Hi everyone,
In JIRA we have custom required fields. We try to create JIRA issues from Confluence directly but getting error:
There were errors creating an issue in JIRA. Some required fields may not be available on this form. Try creating this issue in JIRA
  • duedate: Due Date is required. customfield_10301: ??????????? ????????? (R) is required.
  • Due Date is required.
The problem Create New Issue popup in Confluence doesn't include such fields. Is it possible somehow to configure Confuence marcos to include those fields?
Thanks in advance.
MJ
May 22, 2013
Hi Alexander,
Currently it is not possible to create issues from Confluence if the project in question has additional required field other than the default ones. A bug report has been created for this earlier, you can find it here, if you add yourself as watcher, you will receive updates whenever they become available, and you can leave comments if you wish so.
