Got a problem I haven't seen before and googling didn't help.
My screen configuration shows my new custom field in the correct position but not in the right spot when Creating or Editing. Project only has one scheme for all issue types and one screen.
It's prob worth noting that I created a couple of other custom fields around the same time and they are appearing in the correct position on the screen configuration and while creating/editing.
I've tried a project and a background index and that didn't help. Wondering if a restart would fix it but thought I would ask the community first.
Any help is appreciated.
Ugh, this is a 'my bad'. Screen configuration had two fields with same name and I was positioning the wrong one on the configuration page. Deleted the incorrect one and moved the right one to the correct position. Nevermind...
